BIX extract of work history does not work
We are using PRPC 7.3.1
I created an Extract file using our work history class "History-Org-AppName-Work". Use XML as output format, and selected "Get all properties" checkbox.
After running the Extract file from within the Developer portal, I noticed that the xml generated contains only a few properties.
It contains only pxCommitDateTime, pxObjClass, pzInsKey, nothing else.
Is this a known issue?
***Updated by moderator: Lochan to update platform capability***
Upon reviewing the associated Support Request, the following resolution was found:
Instead of selecting "Get All properties", select individual properties for BIX extract.
