Russian National Reinsurance Company
RU
Last activity: 9 Jan 2020 15:46 EST
BIX extract does not work properly
We have an extract, called BIX_XML_HistoryReinsuranceWork
The result of fullfilment of this extract is in attachment, we have 265 lines in table item.
The problem is next: in this file , we have only 4 columns in table item. But in real the colums should more than 4.
If we will discard the check "get all properties", and select manually the needed columns, the result we get is 0 lines.
The analog case was on this link: https://collaborate.pega.com/question/bix-extract-work-history-does-not-work
