Can we call Next Best Action directly via events using ESM
We have a use case to call NBA using events via ESM; is it possible to directly call the NBA engine via events?
Hi
You can configure the top-level, issue or group node in the Next-Best-Action Designer to be triggered by an event.
As this query is not directly related to any Pega Academy course, I suggest that you move this query to the Pega Support forum for a more detailed discussion.
Regards
Guru
