DE
Last activity: 23 Jun 2016 14:09 EDT
Can we add a certificate to IAC pegagateway to authenticate as a client?
The client has the requirement for the IAC prgateway to connect to a DataPower applicance to be then forwarded to the Pega server. The ssl handshake is succsesful, since we imported the certificate into the jks file in the prgateway. But for an outgoing connection from the gateway to the Datapower a client authentication via ssl certificate is necessary. This is usually configured in Websphere and all applications in the container then use this configuration. But the IAC prgateway seems to be implemented in a way to not use the container settings but to establish its own HTTP connection. Can someone confirm or correct this? Is there any way to solve this requirement?
