    Bank of New York Mellon
Last activity: 23 Dec 2015 2:03 EST
IAC and Siteminder authentication
I have an exitsingIAC implementation in production with siteminder authentication. What I have seen is IAC is only able to authenticate or rather find the authentication activity when the access group in the browser requestor has the same application as the one that you are giving in PegaAppName. This works fine. Now that I am building another application on the same platform, I am not able to make this work as application is different and I cannot have another requestor on the same server.
Is this is as designed by Pega or is this an issue or am I missing something?Browser requestor should use an access group to just authenticate the user and after that should use the appname from the gadget. Using the same application name for unaunthenticated request does not seem to be right.
Let me know if there is a way to solve this. I will also open an SR to confirm the behaviour.
