Can not connect Projects with Agile Studio 7.3.1
Hello :
I am tring to configure my aplications to use Agile Studio . I am using Booking application Pega Training Sample . When i try to connect the Agile Studio at integration and security tab the withard claims that the url is not correct but i just copy and paste the url of the server .
I tried https://host:port/prweb/PRRestService/api as suggested and https://host:port/prweb/api . In both cases The tomcat logs says that
/prweb/PRRestService/api/v1/asauthenticate is not found as you could see:
Hello :
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:15:28 +0100] "GET /prweb/PRRestService/api/v1/as authenticate HTTP/1.1" 404 18
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:15:52 +0100] "GET /prweb/PRRestService/api/v1/as authenticate HTTP/1.1" 404 18
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:25:21 +0100] "GET /prweb/PRRestService/api/v1/as authenticate HTTP/1.1" 404 18
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:32:40 +0100] "GET /prweb/PRRestService/api/v1/as authenticate HTTP/1.1" 404 18
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:45:02 +0100] "GET /prweb/api/v1/asauthenticate H TTP/1.1" 404 18
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:46:03 +0100] "GET /prweb/api/v1/asauthenticate H TTP/1.1" 404 18
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:46:19 +0100] "GET /prweb/api/v1/asauthenticate H TTP/1.1" 404 18
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:46:32 +0100] "GET /prweb/api/v1/asauthenticate H TTP/1.1" 404 18
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:46:33 +0100] "GET /prweb/api/v1/asauthenticate H TTP/1.1" 404 18
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:46:42 +0100] "GET /prweb/api/v1/asauthenticate H TTP/1.1" 404 18
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:46:44 +0100] "GET /prweb/api/v1/asauthenticate H TTP/1.1" 404 18
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:46:45 +0100] "GET /prweb/api/v1/asauthenticate H TTP/1.1" 404 18
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:46:50 +0100] "GET /prweb/api/v1/asauthenticate H TTP/1.1" 404 18
localhost_access_log.2018-03-19.txt:10.0.112.112 - - [19/Mar/2018:18:46:51 +0100] "GET /prweb/api/v1/asauthenticate H
