Can get a property value from the clipboard by using the Java step?
Hi @pundarit,
use the below java code it will resolve your issue.
ClipboardPageworkpage = tools.findPage(pagename);
String propername = workpage.getProperty(“.pxResults.Risk”).toString();
Or
String propertyname= tools.findPage(“WorkListPage”).getProperty(“.pxResults.Risk”).toString();
Sai G
