Set Property on clipboard using java script syntax
Here is my requirement:- I have two sections A and B within Parent Section C. Section B is fully HTML type section where i have to set a clipboard property using simple Java script syntax so that i can put some visibility conditions on section A and also i have to refresh the Parent Section on click of the confirm/alert popup.
So could some one of you please let me know the syntax/method to get this requirement done.
Thanking in advance.
