T-Mobile
Calling a flow action in JS
We have a use case to build Pega case widget to update existing case by passing in certain parameters. We would like a certain flow action to launch when specific parameters is passed in from external application to Pega widget. is there a way to call flow action within a JavaScript code? Thanks for the help.
Hi ,
I have seen customers getting this accomplished with below but never tried , you can have a look:
The JS function name should be of the below format,
For Pre - preFlowAction$FlowActionName
Hi ,
For Post - postFlowAction$FlowActionName
During run time "preFlowAction$FlowActionName" JS function will be invoked before the section gets loaded so ideally this can be used to initialize stuff and "postFlowAction$FlowActionName" JS function will be invoked post submission of flow action so this can be used to update the status of work object or some other properties in the work page.
Ex.
function preFlowAction$CollectEmployeeDetails(flowClass) {
/* business logic goes here*/
function postFlowAction$CollectEmployeeDetails(flowClass) {
Thank you
-Abhishek
T-Mobile
Thank you Abhishek! This looks helpful hint. I will give it a try.
Oumer
Hi Oumer,
You can also try the below code in your JS
call this pega js function in your js function for calling local flow action
pega.u.d.processAction('<flow action name>', '', '','','',true,event);
Korikana Sriraj
T-Mobile
Thank you Vikash. I will try it.
Oumer
TCS
FR
Hi Oumer,
Please let me know ...which one is worked i.e pega.u.d.processAction('<flow action name>', '', '','','',true,event); or
Please provide little more information ..I also need to call a flow-action from Java script
Hi Oumer,
Thnx
Hari
Areteans Technology
NZ
Did anyone try this method and did it work?
Thank you for posting your query in the PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write Post button here. Once created, please reply back here with the URL of the new post.
