Calling two different buttons from same flow action
I have an edit drop/down button to edit "Module Map template". Once clicked the flow: "Draft" is called. But also upon creating a new Module Map Template the status will be "Draft" and same flow will be called. Once flow is called a "Cancel" button appears. My scenario is that I need two different Cancel buttons performing different actions: upon creating new template / or edit Structure template. Any Idea? Note that when pressing on "Edit structure" the harness is not in edit mode to use this as a unique identifier.
Thank you,
Ghina
