- Get Help
Back to top
Back to top
Related content:
Grid width does not fit to screen size dynamically
UI-Kit: 07-01 - Content does not fit whole screen
On Scrolling down the Screen ,Action Button does not work.
Save button in Screen flow
Submit button appearing on the screen
Customising button using Screen flow
On Click on finish Button in screen flow need to navigate to Home screen
fitness tracking usecase
Scroll to top button on right side of screen
Hi Artyom,
I believe this could be because of the repeating grid layout in the section.
1. Please check whether the Responsiveness option is checked under the presentation tab of the repeat grid layout configuration.
2. Open the column properties in the Repeat grid layout and select the Importance for the columns. you can select the importance based on your business needs. The importance marked as Primary will be considered over the rest of the columns.
3. Open the skin rule, select Trees & Grids component, and define the breakpoints appropriately.
https://community.pega.com/support/support-articles/repeating-grid-not-responsive
https://community.pega.com/support/support-articles/horizontal-fit-width-grid-layout-does-not-work-correctly
https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm
Please let me know if this helps.
Gowrishankar.
