ANZ
Last activity: 3 Jul 2017 7:59 EDT
BIX 7.2.2 failing in the command line with JVMCFRE003 error
When i try to execute the BIX in 7.2.2 through command line im getting below exception. Recently we have upgraded from 7.1.7 to 7.2.2.
And also i have replaced rulesets and lib folder accordingly(ojdbc7.jar) and tried pointing to JDK1.7. Please let me know if i miss anything.
Also i tried setting classpath in <filename>_extract.xml file to /****/prbootstrap-api.jar as per the PDN article ref but no luck.
Exception:
Exception:
[echo] Performing Export
[echo] using java version 6
[java] Exception in thread "main" java.lang.UnsupportedClassVersionError: JVMCFRE003 bad major version; class=com/pega/pegarules/pub/PegaRULES, offset=6
[java] at java.lang.ClassLoader.defineClassImpl(Native Method)
[java] at java.lang.ClassLoader.defineClass(ClassLoader.java:286)
[java] at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:74)
[java] at java.net.URLClassLoader.defineClass(URLClassLoader.java:538)
[java] at java.net.URLClassLoader.defineClass(URLClassLoader.java:449)
[java] at java.net.URLClassLoader.access$300(URLClassLoader.java:77)
[java] at java.net.URLClassLoader$ClassFinder.run(URLClassLoader.java:1041)
[java] at java.security.AccessController.doPrivileged(AccessController.java:448)
[java] at java.net.URLClassLoader.findClass(URLClassLoader.java:427)
[java] at java.lang.ClassLoader.loadClass(ClassLoader.java:676)
[java] at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:358)
[java] at java.lang.ClassLoader.loadClass(ClassLoader.java:642)
[java] Could not find the main class: com.pega.pegarules.pub.PegaRULES. Program will exit.
