  Nationale Nederlanden
Last activity: 30 Dec 2016 7:11 EST
BadClassDefinitionException during startup
when we start our PRPC 6.2 SP1 application in our Websphere environment we got the following error:
2016-09-23 10:06:57,940 [pzzapp0274.insim.biz] (     infengine.cbi.GlobalCache) ERROR   - Caught DatabaseException while trying to get classes from entries Database-BadClassDef    History-NN-NNServices-NN-Int-FMig-File-FelixMigrationFile
com.pega.pegarules.pub.database.BadClassDefinitionException: Database-BadClassDef    History-NN-NNServices-NN-Int-FMig-File-FelixMigrationFile
I did check serveral tables etc etc but not able to find from where this is referenced. The class itself has been deleted a quite while ago and the problem exists for a quit long periode. Anyone idea were to check?
Maurice Boer
***Updated by Moderator: Marissa to add SR details***
Hello!
Upon reviewing the corresponding SR, we see that it has been resolved by applying HFix-31023.
Please raise an SR with Pega Global Customer support in you have the same requirement.
Lochan  |  Community Moderator  |  Pegasystems Inc.
Does this prevent the pega engine from starting up? Can you attach the full start-up log?
Hello thank you for your reply.
For some reason I didn't received an alert of this reply. Sorry for the inconvenience.
See attachement.
Maurice
See attachement.
Maurice
Looks like your engine is starting up despite the error. If you can login to the dev portal, can you check the class
History-NN-NNServices-NN-Int-FMig-File-FelixMigrationFile to see which table is mapped to?
Hello Kevin,
thanks for your reply, but this class doesn't exists anymore. I also checked the PR4_Base table but also within this table I am not able to find the class (reference), as expected. So bottomline is where is the system collecting this information from.
Maurice
HFix-5890 addresses this issue in PRPC 6.2 SP2. You could enter an SR to see if it can be ported to PRPC 6.2 SP1.
The error occurs when the class that was deleted had declarative rules associated to it. When the class was deleted the declarative cache entry did not get removed so an error occurs when running the "Starting global declarative cache pre-load..." step.
Hi Maurice,
Please let us know the SR # if you end up opening one!
Marissa | Community Moderator | Pegasystems Inc.
I overlooked the SR request. I will open one today. And it makes sensce what you are saying that it is a cache problem. The error also disappeared when I cleared the cache files in out Test environment. This was needed because of a class inherent changed. The SR entered is SR-B9265. As the we no intent to clear the cache in our Accepance and Production environment. I can confirm it the SR will be succesfull for 6.2 SP1.
Hello!
