CAPGEMINI
SE
Last activity: 21 May 2023 14:33 EDT
Attachment control not recognized when using Pega test Automation Kit
Hello!
I am looking into Pega Test Automation Kit for UI based testing. But I have problem in using this for attachment control. I have read and viewed the release notes, documentation and even video for this control, I can see this was introduced in Automation kit 1.2. But it doesn’t seem to work.
We are on Pega 8.6 and the application uses UI Kit and using OOTB attachment control. Haven’t customized it and that uses pzMultiFilePath control as per the documentation. Based on the notes and video when running/recording the test case number of steps created is also same as in the link above.
Looked into few rules related to this “CanCaptureAttachmentkeys” seems to be the one that might be responsible. Even this when rule returns true.
Will this work only on PegaSocial-Document class ? Normal attachment control or pxAttachContent doesn’t work ?
I am looking for more information on this. Does this functionality works on Test Automation Kit 1.6 ? Was there any changes made ? Would be good to get some information.
Has anyone used and found this to be working ?
I am looking into other test automation tools, but would like to know bit more about this issue.
Thanks!
