Application Test Coverage - Behavior & Inconsistent results
Started a new Test coverage session and I noticed that with running the unit tests manually no coverage report is generated.though per the below article , it is optional, so can someone confirm
Steps followed is started the Coverage session, waited for some time and stopped coverage report showed 0% coverage. Only time I got results was when I manually ran the unit tests
Second issue that I am running into is when the coverage is running and I do some actions in the system say create a new case etc, the coverage report percentages changes, sometimes it drops and sometimes is increases so I'm curious to understand the reason for the same
Note: We are using Pega 8.1.3
