App explorer in the designer 7.1.7 is not showing the class structure and ending with error.
Hello there,
The app explorer in the designer 7.1.7 is not showing the class structure and ending with the below error :
/* Problem executing pzAssemblePreprocess for RULE-HTML-SECTION @BASECLASS PZAPPEXPLORER #20140328T150714.363 GMT com.pega.pegarules.pub.runtime.LibraryFunctionNotFoundException: Problem invoking function: pega_uiengine_pzcontrol.pzActionOpenWizard--(ClipboardPab453fa71666b0404864bd1cd8dd4cdfe, com.pegarules.generated.pzActionOpenWizard_071015_E$CwNA1aRNtDQt9JROOhQw */
Any advice/suggestion will be helpful.
Option tried: Clicked the generate library button in the library : pzControl of Ruleset Pega-UIEngine and server restarted but still the problem exists.
Kapil
Hi there,
Thanks for all the suggestion,'
The temp fix i did is keep @baseclass pzAppExplorer section checked out in private mode and discard it when dev is done. It helps in bringing the app explorer back temporary.
Above is in case you need some temp fix for the issue.
-Kapil Chandak
