Murex
LB
Last activity: 15 Aug 2019 17:32 EDT
Anyone managed to successfully install 8.2?
Did anyone managed to install pega platform 8.2?
We tried both fresh installation and an upgrade. Both are failing....
Elie
Murex
LB
Here's what solved it for US:
ROOT CAUSE
Based on the Thread Dump stack, the system is locked / blocked on Tomcat connection pool implementation.
In Tomcat, there are 2 connection pool types JDBC Connection Pool org.apache.tomcat.jdbc.pool and Apache Commons DBCP connection pool. The default Apache Commons DBCP connection pool can occationally cause Thread blocks.
ROOT CAUSE
RESOLUTION
Use the JDBC Connection Pool org.apache.tomcat.jdbc.pool by including factory="org.apache.tomcat.jdbc.pool.DataSourceFactory" setting in Tomcat's context.xml and restart the server.
<Resource name="jdbc/PegaRULES"
auth="Container"
type="javax.sql.DataSource"
driverClassName="oracle.jdbc.OracleDriver"
url="jdbc:oracle:thin:@host:port:my_sid"
username="db_user"
password="db_password"
maxTotal="100"
maxIdle="30"
maxWaitMillis="10000"/>
Not yet tried with the installation of 8.2 personally, but it would be better if you can able to share at which step it is failing during install/upgrade and what errors are being noticed during that step. That way we can able to help you in finding its root cause.
Mahesh M
Murex
LB
Hello Mahesh Midthuru,
The environment is not starting after the upgrade, nor after a fresh new installation.
The error message is the following:
ERROR - Could not activate managed run [pyFTSIncrementalIndexer] during server startup
java.lang.IllegalStateException: Cannot resume run [pyFTSIncrementalIndexer] with status [Resuming]. Reason: Cannot transition run to Resuming
at com.pega.dsm.dnode.impl.dataflow.task.ResumeRunTask$ResumeTaskResult.generateException(ResumeRunTask.java:113) ~[d-node-8.2.1-225.jar:?]
at com.pega.dsm.dnode.impl.dataflow.task.TaskResultHandler.propagateExceptionIfExists(TaskResultHandler.java:13) ~[d-node-8.2.1-225.jar:?]
at com.pega.dsm.dnode.impl.dataflow.service.DataFlowOperationsRunHandler$6.resume(DataFlowOperationsRunHandler.java:273) ~[d-node-8.2.1-225.jar:?]
Appreciate your help
Thank you
Elie
Based on the above stack trace it seems to be an issue with your DNodes, where it is failing to resume one of your DNode while server start up, may be the respective SMEs should able to help you on this issue. Also you can share the complete stack trace for their analysis going forward.
Murex
LB
Thank you Mahesh Midthuru,
I will let convey the above to our technical admin,
In the meantime any idea why personal edition 8.2 is not available on the website?
Elie
In the meantime any idea why personal edition 8.2 is not available on the website? - not sure why the 8.2 version is not yet available on the website.
Quavo, Inc.
What was the final resolution of this? I'm having the same exact problem. I get the exception you mentioned and then pega hangs and doesn't finish loading.
Murex
LB
I added the correct answer that we got from support.
If it didn;t work, as a workaround we were restarting the complete virutal machine
Quavo, Inc.
The factory thing was the fix for me too. Hopefully they'll update the deploy guides soon. It seems this is pretty widespread after asking around.
Murex
LB
Anyone Else tried to install 8.2? And managed to do it successfully?
Blue Cross Blue Shield of MA
I was able to install 8.2.1 successfully on Windows 10.
On Windows 7 it does not work properly. After logging on using [email protected]/install, it puts me on Dev Studio. This is as expected. However, when I try to create Admission, UIKit is missing and PegaApp cannot be chosen since Radio button is disabled. Unsure what the issue is.
I have tried on 2 different Windows 10 machines. Worked.
I have tried on 2 different Windows 7 machines. Does not work. I realize Windows 7 is seeing it's last days but it should work.
Murex
LB
ROOT CAUSE
ROOT CAUSE
RESOLUTION
auth="Container"
username="db_user"
maxTotal="100"
maxIdle="30"
EvonSys
LK
This has worked for us as well. Thanks.
Social Security Administration
Do this solution works when I have two nodes running?
