Jenkins says success but job is faild
Jenkins says success message when unauthorized or one of job fail, either Export or import, see the bellow
file /tmp/PegaInstallTemp-28-September-2017-09.46.12/EXPORT_1506617172978/jenkins-NGW_Track2_Test-36_1/EXPORTREQUEST-48.log
[java] 09:49:25.630 [main] INFO [viceclient.requestmanager.RequestManager] - Request on system jenkins-NGW_Track2_Test-36 Successful
[java]
[java] FAILED JOBS
[java] --------------------------------------------------------------------------------------------
[java]
[java] System Name : jenkins-NGW_Track2_Test-36
[java] Job ID : EXPORTREQUEST-48
[java] Status : FAILED
[java] Error Messages :
[java] Archive & Logs folder: /home/ngwadm/.jenkins/workspace/NGW_Track2_Test/EXPORT_2017-Sep-28_09-49-25/jenkins-NGW_Track2_Test-36
[java] 09:49:25.688 [main] INFO [viceclient.requestmanager.RequestManager] - Shutting down executor service
[java] 09:49:25.688 [main] INFO [viceclient.requestmanager.RequestManager] - Executor Service shutdown completed
[java] Exception in thread "main" Operation EXPORT failed on jenkins-NGW_Track2_Test-36,
[java] at com.pega.pegarules.serviceclient.ClientMain.executeAndHandleResponse(ClientMain.java:116)
[java] at com.pega.pegarules.serviceclient.ClientMain.main(ClientMain.java:61)
BUILD FAILED
/opt/ngw/pega/deploy/prpcServiceUtils/scripts/utils/prpcServiceUtilsWrapper.xml:172: The following error occurred while executing this line:
/opt/ngw/pega/deploy/prpcServiceUtils/scripts/utils/prpcServiceUtilsWrapper.xml:190: Java returned: 1
36_1/NGWFW_09272017_T2_V7.log
[java] 09:50:01.403 [main] INFO [viceclient.requestmanager.RequestManager] - Request on system jenkins-NGW_Track2_Test-36 Successful
[java]
[java] SUCCESSFUL JOBS
[java]
[java] Job ID : IMPORTREQUEST-74
[java] Status : SUCCESS
[java] Logs : /home/ngwadm/.jenkins/workspace/NGW_Track2_Test/IMPORT_2017-Sep-28_09-50-01/jenkins-NGW_Track2_Test-36
[java] 09:50:01.608 [main] INFO [viceclient.requestmanager.RequestManager] - Shutting down executor service
[java] 09:50:01.609 [main] INFO [viceclient.requestmanager.RequestManager] - Executor Service shutdown completed
[java] 09:50:01.609 [main] INFO [.pega.pegarules.serviceclient.ClientMain] - Execution done
NGW_Track2_Test-36
-cleanup:
[echo] Cleaning up temp directory...
[delete] Deleting directory /tmp/PegaInstallTemp-28-September-2017-09.49.27
performOperation:
[echo] PegaRULES Process Commander import complete.
BUILD SUCCESSFUL
Finished: SUCCESS
***Edited by Moderator Marissa to update categories; update SR Details***
