Wells Fargo
Wells Fargo
Wells Fargo
Posted: Aug 13, 2019
Last activity: Aug 13, 2019
Last activity: 13 Aug 2019 3:41 EDT
Could you please share the documents related to Upgrade Pega 6.3 to Pega 8.1
Ravi Kumar.D
I've not run through this particular upgrade yet.
But you should be able to find the upgrade guides in the following location: -
https://community.pega.com/knowledgebase/products/platform/deploy?product_version=26871
I'd suggest you use the drop-down to select your application server and database types.
Also there is a upgrade page which can be navigated to through the Knowledgebase menu
https://community.pega.com/upgrade
