Alternative to   in Pega 7.2
Hi ,
Please suggest alternative to   in Pega 7.2.
***Updated by moderator: Lochan to add Category***
Hi ,
Can you please elaborate on your use case here? More details are needed in terms of what you are trying to accomplish here.
Hi Shruti,
Can you try replacing ' ' with '\u3000' and share the results.
Thanks You Satish , this worked !!!
Create two word with space in between and convert using the below link either to single byte character or double byte character space and use copy the converted space and use it wherever required.
Hi Shruti,
