Agents : StaticContentCleaner
Could you please explain the significance of StaticContentCleaner ?
Hi Karthik,
Thanks for posting on PSC,
The standard activity Code-.StaticContentCleaner deletes (or "prunes") files from the server file system containing static content, such as images (JPG, PNG, or GIF file type), style sheets (CSS file type) and JavaScript files (JS file types) in the StaticContent folder. Normally running once an hour, this activity deletes extracted static content that is older than NNN days, where NNN is the value of the following setting in the prconfig.xml file:
<env name="http/staticcontentminpruningage" value="NNN" />
Refer for details:-https://pdn.pega.com/community/product-support/question/understanding-staticcontentcleaner
Hope it helps, kindly notify if it does.
Asif
As we work on applicaiton, various static content files ( css, js etc ) gets downloaded. This has the potential to unnecessary increases the clutter in your system and occupy space. .
The purpose of this agent is to periodically clean up those files.
Hi Karthik,
Asif
