Accenture
AES Push log usage data agents is getting failed with same exception..
Exception at 20170823T161948.290 GMT: com.hazelcast.core.HazelcastInstanceNotActiveException: Hazelcast instance is not active!
Exception at 20170823T161948.290 GMT: com.hazelcast.core.HazelcastInstanceNotActiveException: Hazelcast instance is not active! at com.hazelcast.spi.AbstractDistributedObject.throwNotActiveException(AbstractDistributedObject.java:81) at com.hazelcast.spi.AbstractDistributedObject.lifecycleCheck(AbstractDistributedObject.java:76) at com.hazelcast.spi.AbstractDistributedObject.getNodeEngine(AbstractDistributedObject.java:70) at com.hazelcast.topic.impl.TopicProxy.publish(TopicProxy.java:33) at com.pega.pegarules.cluster.internal.PRClusterHazelcastImpl.broadcastSystemPulse(PRClusterHazelcastImpl.java:254) at com.pega.pegarules.data.internal.access.DatabaseImpl.attemptToProcessUpdates(DatabaseImpl.java:2730) at com.pega.pegarules.data.internal.access.DatabaseImpl.processUpdates(DatabaseImpl.java:2322) at com.pega.pegarules.data.internal.access.Saver.save(Saver.java:651) at com.pega.pegarules.data.internal.access.DatabaseImpl.save(DatabaseImpl.java:5108) at com.pega.pegarules.data.internal.access.DatabaseImpl.save(DatabaseImpl.java:5094) at com.pegarules.generated.activity.ra_action_pushlogusagedata_5b19b97cae0347247e60446a7287f691.step26_circum0(ra_action_pushlogusagedata_5b19b97cae0347247e60446a7287f691.java:2071) at com.pegarules.generated.activity.ra_action_pushlogusagedata_5b19b97cae0347247e60446a7287f691.perform(ra_action_pushlogusagedata_5b19b97cae0347247e60446a7287f691.java:549) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3505) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.runActivity(QueueProcessor.java:721) at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:602) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:945) at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1259) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:901) at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:670) at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991) at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532) at java.lang.Thread.run(Thread.java:745)
