Missing GC and Log Usage in SMA
Am not able to see the GC and Log usage option in the SMA, Am using a local VM which is downloaded from academy below is the screen shot.
Hi ,
I can see "Log Usage" option under "Logging and Tracing"(3rd option) in the snap shot provided.
If you are talking about SMA > Logging and Tracing > Garbage Collector and Log Usage feature, then it has been removed from Pega 7.3
Thank You,
