Virtusa India Pvt Ltd
SG
Posted: Apr 15, 2015
Last activity: Jul 18, 2015
Last activity: 18 Jul 2015 17:52 EDT
SQL error when access Garbage Collector And Log Usage from SMA
Hello Everyone - We are seeing the below error when we select Log Usage Statistics and click on View button under Garbage Collector And Log Usage option in SMA.
LogUsageView : SQL exception processing log usage statistics ORA-00933: SQL command not properly ended
Is this a Bug? Is there any workaround or solution to overcome the problem?
Thanks in advance.
Chavan
Your question is over 3 months old so I'm assuming you already contacted GCS. I haven't seen this before and am curious what was discovered.
