Last activity: 17 Jul 2017 15:42 EDT
SQL error when access Garbage Collector And Log Usage from SMA
Re-posting this same question from the PDN forum. While trying to reproduce, I am running into the same problem. PRPC ML6, Tomcat 7, Postgres 9.1. When I try to view the Log Usage Statistics on a node, I get a SQL syntax error:
The failing query is below. The parameters are node ID, start/end date.
SELECT MAX(pxProcessCPU) as "pxProcessCPU", MAX(pxRequestorType) as "RequestorType", MAX(pxSystemNodeID) as "pxSystemNodeID", MAX(pxSystemNode) as "pxSystemNode", MAX(pxSystemName) as "pxSystemName", COUNT(DISTINCT(pxRequestorID)) as "UniqueRequestors", COUNT(DISTINCT(pyUserIdentifier)) as "UniqueUsers", SUM(pxActivationDataTimeCPU) as "pxActivationDataTimeCPU", SUM(pxActivationDataTimeElapsed) as "pxActivationDataTimeElapsed", SUM(pxActivityCount) as "pxActivityCount", SUM(pxAlertCount) as "pxAlertCount", SUM(pxCommitCount) as "pxCommitCount", SUM(pxCommitElapsed) as "pxCommitElapsed", SUM(pxCommitRowCount) as "pxCommitRowCount", SUM(pxConnectCount) as "pxConnectCount", SUM(pxConnectElapsed) as "pxConnectElapsed", SUM(pxDBInputBytes) as "pxDBInputBytes", SUM(pxDBOpExceedingThresholdCount) as "pxDBOpExceedingThresholdCount", SUM(pxDBOutputBytes) as "pxDBOutputBytes", SUM(pxRDBIOElapsed) as "pxRDBIOElapsed", SUM(pxRDBIOCount) as "pxRDBIOCount", SUM(pxDeclarativeRuleReadCount) as "pxDeclarativeRuleReadCount", SUM(pxDeclarativeRulesInvokedCount) as "pxDeclarativeRulesInvokedCount", SUM(pxDeclarativeRulesInvokedCPU) as "pxDeclarativeRulesInvokedCPU", SUM(pxDeclarativeRulesLookupCount) as "pxDeclarativeRulesLookupCount", SUM(pxDeclarativeRulesLookupCPU) as "pxDeclarativeRulesLookupCPU", SUM(pxDeclExprCtxFreeUseCount) as "pxDeclExprCtxFreeUseCount", SUM(pxDeclExprCtxSensUseCount) as "pxDeclExprCtxSensUseCount", SUM(pxDeclNtwksBuildConstCPU) as "pxDeclNtwksBuildConstCPU", SUM(pxDeclNtwksBuildConstElapsed) as "pxDeclNtwksBuildConstElapsed", SUM(pxDeclNtwksBuildHLCPU) as "pxDeclNtwksBuildHLCPU", SUM(pxDeclNtwksBuildHLElap) as "pxDeclNtwksBuildHLElap", SUM(pxDeclRulesInvokedBckGrdCnt) as "pxDeclRulesInvokedBckGrdCnt", SUM(pxDeclRulesInvokedElapsed) as "pxDeclRulesInvokedElapsed", SUM(pxDeclRulesLookupElapsed) as "pxDeclRulesLookupElapsed", SUM(pxDecryptCount) as "pxDecryptCount", SUM(pxDecryptCPU) as "pxDecryptCPU", SUM(pxDecryptElapsed) as "pxDecryptElapsed", SUM(pxEncryptCount) as "pxEncryptCount", SUM(pxEncryptCPU) as "pxEncryptCPU", SUM(pxEncryptElapsed) as "pxEncryptElapsed", SUM(pxFlowCount) as "pxFlowCount", SUM(pxIndexCount) as "pxIndexCount", SUM(pxInferGeneratedJavaCount) as "pxInferGeneratedJavaCount", SUM(pxInferGeneratedJavaCPU) as "pxInferGeneratedJavaCPU", SUM(pxInferGeneratedJavaElapsed) as "pxInferGeneratedJavaElapsed", SUM(pxInferGeneratedJavaHLElapsed) as "pxInferGeneratedJavaHLElapsed", SUM(pxInputBytes) as "pxInputBytes", SUM(pxInteractions) as "pxInteractions", SUM(pxJavaAssembleCount) as "pxJavaAssembleCount", SUM(pxJavaAssembleCPU) as "pxJavaAssembleCPU", SUM(pxJavaAssembleElapsed) as "pxJavaAssembleElapsed", SUM(pxJavaAssembleHLElapsed) as "pxJavaAssembleHLElapsed", SUM(pxJavaCompileCount) as "pxJavaCompileCount", SUM(pxJavaCompileCPU) as "pxJavaCompileCPU", SUM(pxJavaCompileElapsed) as "pxJavaCompileElapsed", SUM(pxJavaGenerateCount) as "pxJavaGenerateCount", SUM(pxJavaGenerateCPU) as "pxJavaGenerateCPU", SUM(pxJavaGenerateElapsed) as "pxJavaGenerateElapsed", SUM(pxJavaStepCount) as "pxJavaStepCount", SUM(pxJavaSyntaxCount) as "pxJavaSyntaxCount", SUM(pxJavaSyntaxCPU) as "pxJavaSyntaxCPU", SUM(pxJavaSyntaxElapsed) as "pxJavaSyntaxElapsed", SUM(pxLegacyRuleAPIUsedCount) as "pxLegacyRuleAPIUsedCount", SUM(pxListRowWithFilteredStrmCnt) as "pxListRowWithFilteredStrmCnt", SUM(pxListRowWithoutStreamCount) as "pxListRowWithoutStreamCount", SUM(pxListRowWithUnfilteredStrmCnt) as "pxListRowWithUnfilteredStrmCnt", SUM(pxListWithFilteredStreamCount) as "pxListWithFilteredStreamCount", SUM(pxListWithoutStreamCount) as "pxListWithoutStreamCount", SUM(pxListWithUnfilteredStrmCnt) as "pxListWithUnfilteredStrmCnt", SUM(pxLookupListDBFetches) as "pxLookupListDBFetches", SUM(pxNewFUAInstances) as "pxNewFUAInstances", SUM(pxOtherBrowseCPU) as "pxOtherBrowseCPU", SUM(pxOtherBrowseElapsed) as "pxOtherBrowseElapsed", SUM(pxOtherBrowseFilterCnt) as "pxOtherBrowseFilterCnt", SUM(pxOtherBrowseFilterCPU) as "pxOtherBrowseFilterCPU", SUM(pxOtherBrowseFilterElapsed) as "pxOtherBrowseFilterElapsed", SUM(pxOtherBrowseReturned) as "pxOtherBrowseReturned", SUM(pxOtherCount) as "pxOtherCount", SUM(pxOtherFromCacheCount) as "pxOtherFromCacheCount", SUM(pxOtherIOCount) as "pxOtherIOCount", SUM(pxOtherIOCPU) as "pxOtherIOCPU", SUM(pxOtherIOElapsed) as "pxOtherIOElapsed", SUM(pxOutputBytes) as "pxOutputBytes", SUM(pxParseRuleCount) as "pxParseRuleCount", SUM(pxParseRuleTime) as "pxParseRuleTime", SUM(pxParseRuleTimeCPU) as "pxParseRuleTimeCPU", SUM(pxPassivationCount) as "pxPassivationCount", SUM(pxPassivationDataTimeCPU) as "pxPassivationDataTimeCPU", SUM(pxPassivationDataTimeElapsed) as "pxPassivationDataTimeElapsed", SUM(pxPassivationIdleTimeElapsed) as "pxPassivationIdleTimeElapsed", SUM(pxPassivationSizeAverage) as "pxPassivationSizeAverage", SUM(pxPassivationSizeLast) as "pxPassivationSizeLast", SUM(pxPassivationSizePeak) as "pxPassivationSizePeak", SUM(pxProceduralRuleReadCount) as "pxProceduralRuleReadCount", SUM(pxPropertyReadCount) as "pxPropertyReadCount", SUM(pxRDBRowWithoutStreamCount) as "pxRDBRowWithoutStreamCount", SUM(pxRDBRowWithStreamCount) as "pxRDBRowWithStreamCount", SUM(pxRDBWithoutStreamCount) as "pxRDBWithoutStreamCount", SUM(pxRDBWithStreamCount) as "pxRDBWithStreamCount", SUM(pxRuleBrowseCPU) as "pxRuleBrowseCPU", SUM(pxRuleBrowseElapsed) as "pxRuleBrowseElapsed", SUM(pxRuleBrowseFilterCnt) as "pxRuleBrowseFilterCnt", SUM(pxRuleBrowseFilterCPU) as "pxRuleBrowseFilterCPU", SUM(pxRuleBrowseFilterElapsed) as "pxRuleBrowseFilterElapsed", SUM(pxRuleBrowseReturned) as "pxRuleBrowseReturned", SUM(pxRuleCount) as "pxRuleCount", SUM(pxRuleCPU) as "pxRuleCPU", SUM(pxRuleFromCacheCount) as "pxRuleFromCacheCount", SUM(pxRuleIOElapsed) as "pxRuleIOElapsed", SUM(pxRulesExecuted) as "pxRulesExecuted", SUM(pxRulesUsed) as "pxRulesUsed", SUM(pxRunModelCount) as "pxRunModelCount", SUM(pxRunOtherRuleCount) as "pxRunOtherRuleCount", SUM(pxRunStreamCount) as "pxRunStreamCount", SUM(pxRunWhenCount) as "pxRunWhenCount", SUM(pxSavedCbAfterIntCount) as "pxSavedCbAfterIntCount", SUM(pxSavedCbAfterIntCPU) as "pxSavedCbAfterIntCPU", SUM(pxSavedCbAfterIntElapsed) as "pxSavedCbAfterIntElapsed", SUM(pxSavedCxtAfterIntCount) as "pxSavedCxtAfterIntCount", SUM(pxSavedCxtAfterIntCPU) as "pxSavedCxtAfterIntCPU", SUM(pxSavedCxtAfterIntElapsed) as "pxSavedCxtAfterIntElapsed", SUM(pxServiceActivityCPU) as "pxServiceActivityCPU", SUM(pxServiceActivityTime) as "pxServiceActivityTime", SUM(pxServiceCount) as "pxServiceCount", SUM(pxServiceDataVolume) as "pxServiceDataVolume", SUM(pxServiceInMapReqCPU) as "pxServiceInMapReqCPU", SUM(pxServiceInMapReqTime) as "pxServiceInMapReqTime", SUM(pxServiceNumFileRecords) as "pxServiceNumFileRecords", SUM(pxServiceOutMapReqCPU) as "pxServiceOutMapReqCPU", SUM(pxServiceOutMapReqTime) as "pxServiceOutMapReqTime", SUM(pxTotalReqCPU) as "pxTotalReqCPU", SUM(pxTotalReqTime) as "pxTotalReqTime", SUM(pxTrackedPropertyChangesCount) as "pxTrackedPropertyChangesCount", SUM(pxTransientJavaAssembleCount) as "pxTransientJavaAssembleCount", SUM(pxTransientJavaAssembleCPU) as "pxTransientJavaAssembleCPU", SUM(pxTransientJavaAssembleElapsed) as "pxTransientJavaAssembleElapsed", SUM(pxTransientJavaCompileCount) as "pxTransientJavaCompileCount", SUM(pxTransientJavaCompileCPU) as "pxTransientJavaCompileCPU", SUM(pxTransientJavaCompileElapsed) as "pxTransientJavaCompileElapsed" FROM pegadata.pr_perf_statsWHERE (pxSystemNodeID = ?) AND (pyUserIdentifier IS NULL OR pyUserIdentifier <> 'Guest Content') AND (pxRequestorType <> 'BATCH') AND (pxSnapshotTime BETWEEN ? AND ?)
In addition, when trying to view the Garbage Collector Statistics, I get the error "GarbageCollectorView: null
