Adding forwards and backwards buttons to the Portal
I have a requirement to add a backward and forward buttons to a user portal, so the users can navigate between screens to correct any mistakes made during case processing. Currently the user (Agent) has to start from the beginning to make any changes.
In this case I don’t think a ‘forward button’ is required as each screen has a Submit button to progress, but I need to somehow insert a ‘Back’ button onto each screen allowing the user to go back to the previous screen and change any details they’d previously set, and then submit to the next screen again.
I’ve included a brief outline of the journey that the user goes through.
Screen 1 (Start interaction) – The user selects some information and clicks submit. No back button is required here as this is the first screen
Screen 2 (Process Query) – More information is filled out here and the Submit button is clicked
Screen 3 (Send Resolution Email) – The user can send an email to the customer confirming the action taken. There is submit button (out of view), next to which a back button could be placed, to take the user back to the previous ‘Process Query’ screen.
Is there a straight forward way of implementing this?
@AlexS7887
If all these screens will be performed by one Single user, then you can leverage screen flow to make it easier for the users to navigate back and forth between the screens. The users will see the breadcrumb as well which will help them to visualize the next steps in the case workflow.
https://docs-previous.pega.com/case-management/87/creating-screen-flow?
