Last activity: 11 Sep 2019 5:00 EDT
Adding cases for the WebChat channel
Dear All,
have any one tried "Adding cases for the WebChat channel" ,it is not working for me, I don't see any error in Tracer and Log files but in preview console i see "The chatbot is experiencing problems. If the issue is related to your current case, you can withdraw it by typing cancel." .. any suggestion please.
Adaps
Please find the below link it will help you
Raveendra , the link specified by you, will not help
CAPGEMINI
SE
Thank you for posting your query in the PSC. This looks like an inactive post and hence, we suggest you create a new post for your query. Click on the Write Post button here. Once created, please reply back here with the URL of the new post.
it is working fine in Pega 8.1 without any issue , which version you are trying and what is written in log , have you traced the error ?
CAPGEMINI
SE
No Error in the tracer.
2019-01-31 07:46:18,739 [se-nio2-9443-exec-37] [TABTHREAD0] [ ] [imAutomated:01.01.01] (learNLPCache._baseclass.Action) INFO infosys1.pegalabs.io|127.0.0.1 sarath - Clearing cache called for:Taxonomy 2019-01-31 07:54:24,933 [se-nio2-9443-exec-71] [TABTHREAD1] [ ] [imAutomated:01.01.01] (pages.DeclarativePageUtilsImpl) WARN infosys1.pegalabs.io|127.0.0.1 sarath - Required parameter'TAName' for data page 'D_pyEntityClassMapping' cannot be blank. 2019-01-31 07:54:24,933 [se-nio2-9443-exec-71] [TABTHREAD1] [ ] [imAutomated:01.01.01] (pages.DeclarativePageUtilsImpl) WARN infosys1.pegalabs.io|127.0.0.1 sarath - Required parameter'TAClassName' for data page 'D_pyEntityClassMapping' cannot be blank.
These are the few errors which i noticed. BTW i havent configured any Text analyzer rule
we are in pega 8.1.2
USU GmbH
DE
seems I got the same Issue.
How did you solve it?
We are working with Pega 8.1.3.
This is what I have found in the Logs:
2019-09-10 14:40:05,976 [tp-nio-8080-exec-598] [TABTHREAD4] [ ] [usInsurance:01.01.01] (pages.DeclarativePageUtilsImpl) WARN pegadev1.xyz.grp| - Required parameter'TAName' for data page 'D_pyEntityClassMapping' cannot be blank.
2019-09-10 14:40:05,976 [tp-nio-8080-exec-598] [TABTHREAD4] [ ] [usInsurance:01.01.01] (pages.DeclarativePageUtilsImpl) WARN pegadev1.xyz.grp|- Required parameter'TAClassName' for data page 'D_pyEntityClassMapping' cannot be blank.
This message is 'Internal error' system response which usually means case is not configured properly. Either parallel process is not set up or flow encountered an assignment shape. When you trace, can you verify whether service case is created and what is the flow it goes in.
