Datacom group
NZ
Last activity: 1 Nov 2017 16:58 EDT
Adding Application Configuration files
I found these links for adding configuration files for different environments in OpenSpan. I am using Pega robotics plug-in for VS and though I could add configuration files, I couldn't find the configure option when I right-click controls as described in the following links.Can anyone share some resource that tells how to setup configuration files to use in different environments?
http://help.openspan.com/52/Project_Configuration_and_Deployment/Add_Configuration_Item2.htm
http://help.openspan.com/52/Project_Configuration_and_Deployment/Configuration_Deployment.htm
