Datacom group
NZ
Last activity: 15 Mar 2018 23:30 EDT
Robotics project Configuration file
One of the user stories I was working these days got a requirement that most of the string values used in the project should be referenced from an excel file so that after going live the user can change the sting values in excel to manage the system.For an example, I am providing the path of an word document file to an automation as a string value and if we can save that string in an excel file, the user can change the file path if we can have that configuration value in an external file.How to use such a configuration file in Pega robotics?
Use the path as a global variable. Once you get the path from excel set the variable and use it in automations.
