Using configuration files
I have a multi-project solution and in two of the projects I would like to change the executable path for the adapters in those projects, depending on the configuration set. There are also a few other settings but that is where we are starting. I have created a pair of configuration files in the startup project as well as the other projects where the settings need to apply, as I read in the post at https://collaborate.pega.com/question/pega-robotics-8x-how-apply-configuration-profiles-each-project-multi-projects-solution. The configuration files in the sub-projects are named the same as the ones in the startup project. When I deploy, the server sees both configurations and allows me to apply one when I assign it to a user. When I run the automation and check the settings, it only shows the string that was in the setting in Studio, not the one which should have been applied through the configuration.
I'm pretty sure I'm just missing a step, but I haven't been able to find anything in the documentation to point me in the right direction.
***Edited by Moderator Marissa to add SR Details***
