About the warning message output by rebuild after updating from pega 19.1.76.0 to 19.1.94.0
Dir Sir/Madam
The following warning message was output when rebuilding after the update. Does this affect the execution?
Also, please tell me how to solve it.
Found conflicts between different versions of the same dependent assembly that could not be resolved. These reference confricts are listed in the build log when log verbosity is set to detailed.(Microsoft.Common.CurrentVersion.targets)
Could not resolve this reference. Could not locate the assembly "log4net, Version= Proprietary information hidden, Culture=natural, PublicKeyToken=669e0ddf0bb1aa2a". Check to make sure the assembly exists on disk. If this reference is required by your code, you may get compilation erros.(Microsoft.Common.CurrentVersion.targets)
thank you in advance.
