PNC
Last activity: 6 Apr 2018 19:26 EDT
722 extractedFile location in linux servers
HI,
In PEGA 722 we are planning to change extractedFiles directory to some other place in Linux servers (example location cd /app/projectrelated/temp) location.
and we have created that directory in servers and created JVM argument in Websphere (under Middile ware server> servername >Process definition > Java Virtual Machine > Custom properties). and directory has sufficient privileges to read also.
after above setting were made, we stopped servers and brought up the server. but extractedFiles directory location is something else not mentioned above..
FYI : I know that it will work in PEGA 717 because we did same settings and other environments are working fine and extractedFiles location also as per setting (as per location) in 717 servers.
This is I noticed for 722 servers after update from 717.
So question is - in 722 can we able to change this location, if yes is there any other settings need to be done ?
Thank you
Naresh
