Issue
In Pega Customer Service™ release 25.1.4, the agent work area for email and chat interactions is displayed as blank in the Interaction Portal when AI Companion is enabled. Disabling AI Companion restores normal rendering.
Symptoms and Impact
When an agent opens an email or chat interaction with AI Companion enabled, the right-panel work area is blank.
Knowledge Management article content loads and overlays the email and chat panes, making them inaccessible until the Knowledge Management panel is manually closed. All email and chat interactions handled through the Interaction Portal are affected.
Disabling AI Companion resolves the display issue, confirming that the defect is specific to the interaction between AI Companion and the Interaction Portal right-panel layout.
This issue is introduced following an update to Pega Infinity '25.1.4.
Steps to reproduce
- In App Studio, ensure that the cyIsAICompanionEnabled configuration flag is set to true and Save.
- Log in to the Interaction Portal.
- Open an email or chat interaction.
- Result: The agent work area in the right panel is displayed as blank. Knowledge Management content overlays or hides the email or chat pane.
- Navigate to App Studio and set cyIsAICompanionEnabled to false, then Save.
- Return to the Interaction Portal and open an email or chat interaction.
- Result: The agent work area renders correctly.
Root Cause
This is a confirmed product-level defect.
A CSS conflict in the pega_cpm_IP_EventManager Rule, introduced as part of the application-custom-css changes in Pega Infinity '25.1.4, disrupts the right-panel layout when AI Companion is active. The updated CSS causes Knowledge Management article content to load over the email and chat panes, rendering them inaccessible.
Solution
Install HFIX-D4851 to resolve the issue in Pega Infinity '25.1.4.
A permanent fix is targeted for a later release of Pega Customer Service.
Hotfix installation steps:
- Identify the lowest available environment for testing.
- Take a database snapshot of that environment.
- Commit all currently uncommitted hotfixes.
- Install hotfix HFIX-D4851 using the Hotfix Manager.
- Do not commit the new hotfix at this stage (rollback will not be possible after committing).
- Shut down all JVMs and perform a clean restart.
- Validate that email and chat interactions render correctly with AI Companion enabled.
Local Change (Workaround)
To restore email and chat functionality without applying the hotfix, disable AI Companion by setting the cyIsAICompanionEnabled configuration flag to false in App Studio. Note that this disables AI Companion for all interactions.
