Issue
In Pega Customer Service™ '25.1 on Pega Constellation, the action is not implemented as a Case-wide action with a pyLocalActionName and an associated view. In implementations that use Pega Customer Service™ capabilities with a multi-tier case hierarchy such as Pega Smart Investigate Agentic Automation, emails associated with child cases are not displayed on the Orchestration Case in the Utilities panel. Examples include Orchestration Cases associated with Dispatch and Resolution Activity Cases.
Symptoms and Impact
The pyGetEmailsOnLinkedCase rule is marked as final in customer service so users cannot configure their requirements.
Steps to reproduce
- Implement Pega Smart Investigate Agentic Automation (SIAA) on Pega Customer Service.
- Configure email processing for a use case like Dispatch, Orchestration, and Resolution Activity case types.
- Create an Orchestration case with related Dispatch and Resolution Activity cases that contain associated emails.
- Open the Orchestration case.
- In the Utilities panel attempt to view the emails associated with the related Dispatch and Resolution Activity cases.
- Result: The emails associated with the related cases are not displayed on the Orchestration case.
Root Cause
This is a product feature gap. The pyGetEmailsOnLinkedCase activity controls how Customer Service retrieves and displays emails from linked Cases. Although Pega Platform™ exposes this activity as an extension point, the Customer Service layer overrides it and marks it as final, which prevents any further override or customization in downstream application layers.
The out-of-the-box mechanism for displaying emails on a Case requires that the Case is directly linked to an Email Triage case, with EmailCaseKey populated. This works for the standard Interaction–Service Case pattern in Customer Service, where multiple Service Cases under a single Interaction can each surface their associated emails. It does not extend to custom hierarchies where multiple email threads are linked to separate Dispatch Cases under a shared Orchestration Case.
Two additional constraints apply:
- Outbound emails sent through Resolution Activity Cases do not create corresponding Email Triage cases, so those emails have no path to surface on the Orchestration Case.
- Linking Email Triage cases directly to the Orchestration Case as a workaround causes duplicate attachments to appear across linked Orchestration and Resolution Activity Cases.
Solution
The Customer Service and Smart Investigate Agentic Automation product teams are evaluating the use case to determine the appropriate approach for providing a supported extension point in a future release.
Additional information
The standard supported approach for surfacing emails on a Case is:
- Link the Case directly to the Email Triage (I-) case.
- Ensure EmailCaseKey (the Email Triage case's InsKey) is available on the Case and passed to the D_pxEmailsOnCase data page call.
This approach is not viable when multiple email threads are distributed across separate child Cases in a custom hierarchy, which is the scenario that the enhancement request addresses.
