Issue Images referenced by an external URL do not display in generated PDFs on Pega Platform. Symptoms and Impact Generated PDFs render successfully, but images sourced from an external HTTP or HTTPS…
Issue When an operator’s maximum concurrent session limit is set to 1, signing in from another browser session on a different node does not invalidate the existing browser session. Both sessions remain…
The accessibility issue involves improper sequencing of HTML heading tags within the Pega Constellation UI framework, impacting users relying on assistive technologies. This defect violates WCAG standards…
When you have multiple SAML SSO authentication services configured, Pega Platform renders a button on the login screen for each active service. You may want to hide specific SSO buttons — for example,…
Overview Pega Platform™ '26.1 introduced changes to the SOAP connector integration framework due to architectural refactoring. The refactoring included an upgrade of the Apache Axis2 open source…
Traditional UI in Constellation (Blended UI) landing pages fail to load for business users in Production with an HTTP 400 Bad Request error, while administrators are unaffected. This article explains the…
Issue Export to Excel from Constellation list Views and reports generates files containing only headers and no rows when data pages use queryable Data Pages with dynamic filter conditions. Symptoms and…
Issue When a table is configured using an Embedded List as its data source, the Search icon functionality does not return results. Entering a valid search term causes the table to display zero rows…
Charts failed to render after upgrade to Pega Platform 26.1.0 in a Traditional UI / UI Kit application. Root cause is a JavaScript conflict introduced by the AppDynamics ADRUM agent, which overrides the…
Executive Summary - Action Required Pega regularly implements security controls designed to safeguard client environments. As part of these efforts, Pega will release patch updates and hotfixes addressing…
Read More
0
We'd prefer it if you saw us at our best.
