Overview
Pega is introducing significant enhancements to the Client-Managed Cloud (CMC) deployment experience. These changes deliver more secure, flexible, and modern deployment assets for Kubernetes-based environments, including hardened Docker image variants, an improved image tagging strategy, an updated base operating system, and a consolidated image repository.
What Is Changing
1. Hardened Docker Image Variants
New hardened Docker images are now available, built from hardened base images. These provide:
- A significant reduction in Common Vulnerabilities and Exposures (CVEs)
- Faster CVE remediation timelines
- An improved overall security posture for Client-Managed Cloud deployments
2. Improved Image Tagging Strategy
A new, more descriptive image tagging strategy has been introduced to make image selection easier and more predictable. Date-stamped image tags will be published.
Tag format details and examples are documented in the "Determining which Docker images to use for your deployment" section of the Pega Docker images management guide.
3. Ubuntu 26.04 LTS Base Image
The base operating system has been updated from Ubuntu 24.04 to Ubuntu 26.04 LTS. Ubuntu-based images remain available and are backward compatible with previously published Ubuntu 24.04 images.
Ubuntu-based images continue to be available for download via Pega-managed Docker image repository.
4. Consolidated Image Repository
Effective January 4, 2027, new deployment images will be published only to Pega's managed Docker image repository. Images will no longer be published to Docker Hub.
Clients who currently pull images from Docker Hub must update their configurations to reference Pega's managed repository before this date.
Helm Chart Changes
Current State :
The current Helm chart version is 4.17.0.
Upcoming 5.x Release (January 2027):
A new 5.x major version of the Pega Helm charts will be released in January 2027. Key details:
- The 5.x release will include updated and expanded documentation within the chart README files.
- The only functional change introduced in 5.x is the alternative initContainer method for downloading the JDBC driver (see JDBC Driver section below).
- Ubuntu-based v4 images will continue to include curl and will work with v5 Helm charts without any required configuration changes.
- The recommendation is to use the latest Helm charts with the latest hardened v4 images.
Ubuntu 26.04 with the New Major Helm Chart Version
There are no required settings or configuration changes when using Ubuntu-based v4 images with the v5 Helm charts.
JDBC Driver Deployment
Recommended Approach
With the hardened v4 images, the primary recommended approach for JDBC driver injection is to build your own images that add the JDBC driver on top of Pega's hardened v4 base images. This approach is fully compatible with the hardened image model
Alternative Approach
As an alternative, you can use an initContainer that runs an image with curl to download the JDBC driver at deployment time. This method is documented in the Pega Helm charts README.
Note: Ubuntu-based v4 images retain curl and therefore continue to support the driverUri proxy approach used in prior deployments.
Scope of This Document: Platform runtime and installer images only
The announcement and the associated changes are focused specifically on the new v4 Docker images and the v5 Helm chart release. Changes to other services, including Search and Reporting Service (SRS) and clustering-service, are outside the scope of this document. Clients with questions specific to those images should raise a separate Support ticket via My Support Portal.
Summary of Key Dates
Date |
Change |
November 2, 2026 |
Hardened v4 images available; improved tagging and Ubuntu 26.04 images published |
January 4, 2027 |
Hardened images become the default; Docker Hub publishing discontinued; v5 Helm charts released |
Action Checklist
- Review the updated Docker image selection guidance and new tagging strategy at: Understanding the Pega-provided Docker images
- Assess your current Helm chart version and plan an upgrade to the latest available version.
- Review the Pega Helm charts README for JDBC driver deployment options: Pega Helm chart Readme
- Update any custom Docker image build processes to build on top of the hardened v4 base images.
- Ensure your environment has access to Pega's managed Docker image repository and plan migration away from Docker Hub before January 4, 2027.
- Test deployments using hardened v4 images in non-production environments ahead of the transition date.
External References
Understanding Pega GitHub resources — Docker Pega Web Ready section:
