Error in Pega Insights with dual average value calculation
If we add two average values together to any insights the values are calculated incorrectly.
1. Add interaction time to insights and configure it to display as average as part of measurement ( InteractionTime Final rule - decimal)
2. Add focus time to insights and configure it to display as average as part of measurement (FocusTime OOTB rule - integer)
3. Along dimensions add some value such as channel
Output :
The average values for interaction time and focus time is incorrect
Expected Output :
The average values for interaction time and focus time should be correctPlease note : If we add only one average value in measurements, the value is correct. On adding two values the calculations are completely  incorrect.
