How to check if a property exists in Pega Database
I want to execute a step if a Property is created in Pega (not exposed) , I am looking for if there is any function or any way to check this?
Hi @ANITAK17,
if you want to conditionally execute a step when a property is created (but not exposed), you have a few options depending on what you mean by "created" — whether it means initialized for the first time, set to a value, or present on the clipboard.
When: @PropertyExists(.MyProperty) Then: Set .AnotherProperty = "Property was created"
Mohd Qizer Uddin
You can use below function to verify if a property is present on a page(even if not initialised).
@PropertyExists(.PropertyName)
there is another function- Utilities • isDBColumn() which would check for a DB column and verifies if a created property has a corresponding column or not in DB.
Did you mean whether a property rule has been created with the given name and applies to any class?
