Wells Fargo
Last activity: 5 Mar 2018 8:49 EST
To check the parameter value exists as property in clipboard
I have value called X present in the parameter- Y in activity. Now I have to check whether this X is present on the Workpage as a property. I am trying some java methods like mysteppage.contains(Y) and mysteppage.equals(Y). But those are not working. Any help is appreciated.
Thank you
HI Rakesh,
You can try with PropertyExists(String) function which checks the existence of the provided property on the current step page.
Hope this helps you.
Regards
Mahesh
