Container startupProbe?
Are folks using startupProbe in their container yaml configurations? We currently have liveness and readiness probes, but we've run into issues with startup times. I am curious if folks have also encountered.
@DPCLARK12 Yes, using startupProbe
is a good idea if your container takes time to start. Without it, the livenessProbe
might kill the container too early, thinking it's stuck when it's just starting up. The startupProbe
runs first and gives your app time to finish loading. Only after it succeeds do the liveness
and readiness
probes begin. This avoids false restarts and helps with stability. You can set it with a high failureThreshold
and longer periodSeconds
to give your app enough buffer. For example, if your app takes up to 5 minutes, use failureThreshold: 30
and periodSeconds: 10
. This gives 300 seconds for the app to get ready. It’s helpful for apps with slow boot, like Java or data-heavy workloads.
