JP Morgan Chase
Last activity: 21 May 2025 6:36 EDT
BIX - Not extracting records based on pxcreatedatetime from an external table
Hi Team,
Our app has a table which has some of the default properties used by PEGA ,but not in its completeness. The table does have pxcreatedatetime/pxupdatedatetime. But it doesn't have pzinskey/pzpvstream/pxcommitdatetime/pxsavedatetime etc. We defined an extract rule based on pxcreatedatetime (>= Last Run Extraction Time). But upon running the extract rule ,no records are extracted. Also if you do test connectivity on class ,it shows below message warning
Can anyone please help on how to get the BIX Extract work on this table.
This is an Obj-external class. You may access the class with Obj- activity methods.Class xxxx is mapped to foreign data table TABLENAME in database PegaDATA, but it contains a px, py, or pz property: pxCreateDateTime
