Cornèr Banca S.A.
CH
Last activity: 30 Apr 2025 17:20 EDT
Change stage in Subprocesses
We have a change stage in a subprocess and the behaviour we observed is that the parent flow proceed as if the subprocess reached the end shape.
The automation "Change to a Stage" should clean up all the processes as "CleanUpProcesses" parameter is defaulted to true, but the result is that we have a new flow in the new stage and the parent flow in the old stage (when we have an assignment otherwise the parent flow follow its route and closes).
The same behaviour is observed when we force close the case (causing active assignment on closed cases or other unexpected behaviours).
In some old documentation (Pega 7 or 8) there is this phrase: "By default, the calling flow waits for the subprocess to finish running before it moves to the next shape in the sequence." But this isn't present in the new documentation.
Is this working as intended? Are we using subprocesses in a wrong way? Or we should open a SR?
