molina
Last activity: 17 Mar 2025 16:33 EDT
Unable to create a Pega Robotics Project / Solution
when i try to create an emty project it keeps spinning. if i try using wizard the Framework dropdown is empty. Below is the error i see in the log
'' BuildError task: The reference assemblies for framework ".NETFramework,Version=v4.6.1" were not found. To resolve this, install the SDK or Targeting Pack for this framework version or retarget your application to a version of the framework for which you have the SDK or Targeting Pack installed. Note that assemblies will be resolved from the Global Assembly Cache (GAC) and will be used in place of reference assemblies. Therefore your assembly may not be correctly targeted for the framework you intend. (Microsoft.Common.CurrentVersion.targets)
I tried to install both 4.6.1 and 4.8. I get FW or a later update is already present.
