Delegation rules tab in interaction portal in pega constellaton
I have a requirement to create a tab in the interaction portal which will display all the rules that I have delegated and the user will be able to edit the delegated rules using that tab. I have followed a documentation provided by pega, however the end result is that we have to launch Case manager portal and also in one of the steps the rule mentioned - pyPopulateAdditionalNavPages - is a final rule which can not be edited. However, as per my requirement I need the tab to be present in Interaction Portal itself so that the customer does not need to launch a new portal to make the changes. Pega documentation link -
https://docs.pega.com/bundle/platform-88/page/platform/app-dev/delegating-rules-data-type-2.html
