Direct link to spesific menu
How to create a Direct link?
User get a link > Login > User is directed to the intended menu (Not to the Dashboard)
Thank You
Thank You
Try using a Parameterized Link - Provide a link to users like:
http://<server-name>:<port>/prweb/<portal-name>?<custom-parameters>
pyStreamName=<section-name>pyActivity=<activity-name>or
Identify the Target Menu/Page
Build the URL
Pega URLs generally follow this pattern:
http://<server-name>:<port>/prweb/<portal-name>?pyActivity=Data-Portal.ShowDesktop&pyStreamName=<section-rule-name>&pzPrimaryPageName=<page-name>
Test the direct link with different users and roles.
