Virtusa private limited
Last activity: 13 May 2025 12:30 EDT
java.io.IOException: java.lang.reflect.InvocationTargetException
at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.run_(JMSListener.java:751) ~[printegrint.jar:?] at com.pega.pegarules.integration.engine.internal.services.listener.ServiceListenerBaseImpl.run(ServiceListenerBaseImpl.java:476) ~[printegrint.jar:?] at java.lang.Thread.run(Thread.java:829) ~[?:?] 2024-11-28 05:30:45,082 [ JMS-Thread-64] [ ] [ ] [ ] ( basic.config.SettingsImpl) ERROR JMS.JMSSwiftInboundListenerSAA3 JMSSwiftInboundAgent - The setting Services/JMSListener/JMSSwiftInboundListenerSAA3/AllowResponse is not present in PrConfigSettingsRegistry. API is depreciated. Please use new API to get the setting information. java.lang.Exception: Information : Setting does not exist in PrConfigSetting enum. at com.pega.pegarules.exec.internal.basic.config.SettingsImpl.logMessageForDepreciatedAPI(SettingsImpl.java:803) ~[prprivate-exec.jar:?] at com.pega.pegarules.exec.internal.basic.config.SettingsImpl.getAsBoolean(SettingsImpl.java:387) ~[prprivate-exec.jar:?] at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.initializeConnection(JMSListener.java:1052) ~[printegrint.jar:?] at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.runPoller(JMSListener.java:756) ~[printegrint.jar:?] at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.run_(JMSListener.java:751) ~[printegrint.jar:?]
at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.run_(JMSListener.java:751) ~[printegrint.jar:?] at com.pega.pegarules.integration.engine.internal.services.listener.ServiceListenerBaseImpl.run(ServiceListenerBaseImpl.java:476) ~[printegrint.jar:?] at java.lang.Thread.run(Thread.java:829) ~[?:?] 2024-11-28 05:30:45,082 [ JMS-Thread-64] [ ] [ ] [ ] ( basic.config.SettingsImpl) ERROR JMS.JMSSwiftInboundListenerSAA3 JMSSwiftInboundAgent - The setting Services/JMSListener/JMSSwiftInboundListenerSAA3/AllowResponse is not present in PrConfigSettingsRegistry. API is depreciated. Please use new API to get the setting information. java.lang.Exception: Information : Setting does not exist in PrConfigSetting enum. at com.pega.pegarules.exec.internal.basic.config.SettingsImpl.logMessageForDepreciatedAPI(SettingsImpl.java:803) ~[prprivate-exec.jar:?] at com.pega.pegarules.exec.internal.basic.config.SettingsImpl.getAsBoolean(SettingsImpl.java:387) ~[prprivate-exec.jar:?] at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.initializeConnection(JMSListener.java:1052) ~[printegrint.jar:?] at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.runPoller(JMSListener.java:756) ~[printegrint.jar:?] at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.run_(JMSListener.java:751) ~[printegrint.jar:?] at com.pega.pegarules.integration.engine.internal.services.listener.ServiceListenerBaseImpl.run(ServiceListenerBaseImpl.java:476) ~[printegrint.jar:?] at java.lang.Thread.run(Thread.java:829) ~[?:?] 2024-11-28 05:30:45,418 [ JMS-Thread-67] [ ] [ ] [ ] ( basic.config.SettingsImpl) ERROR JMS.JMSSwiftInboundListenerSAA4 JMSSwiftInboundAgent - The setting Services/JMSListener/JMSSwiftInboundListenerSAA4/AllowResponse is not present in PrConfigSettingsRegistry. API is depreciated. Please use new API to get the setting information. java.lang.Exception: Information : Setting does not exist in PrConfigSetting enum. at com.pega.pegarules.exec.internal.basic.config.SettingsImpl.logMessageForDepreciatedAPI(SettingsImpl.java:803) ~[prprivate-exec.jar:?] at com.pega.pegarules.exec.internal.basic.config.SettingsImpl.getAsBoolean(SettingsImpl.java:387) ~[prprivate-exec.jar:?] at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.initializeConnection(JMSListener.java:1052) ~[printegrint.jar:?] at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.runPoller(JMSListener.java:756) ~[printegrint.jar:?] at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.run_(JMSListener.java:751) ~[printegrint.jar:?] at com.pega.pegarules.integration.engine.internal.services.listener.ServiceListenerBaseImpl.run(ServiceListenerBaseImpl.java:476) ~[printegrint.jar:?] at java.lang.Thread.run(Thread.java:829) ~[?:?] 2024-11-28 05:30:45,495 [til LISTENER_STARTUP] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO JMSSwiftInboundAgent - Startup Task: [com.pega.pegarules.session.internal.async.startup.ListenerStartupTask] completed in 16775 ms 2024-11-28 05:30:46,282 [egaRULES-MasterAgent] [ STANDARD] [ ] [ ] ( AgentConfiguration) INFO - All startup agent finished, set node's run state to running!!! 2024-11-28 05:30:53,092 [ PegaRULES-Batch-12] [ STANDARD] [ ] [ GPI:01.99.99] (Data_InterdictionReport.Action) INFO - \ 28-Nov-2024 05:30:53.614 WARNING [IK-PROD-BATCH-NODE] org.apache.tomcat.util.scan.StandardJarScanner.processURLs Failed to scan [file:/usr/local/tomcat/lib/jakarta.jms-api.jar] from classloader hierarchy java.io.IOException: java.lang.reflect.InvocationTargetException at org.apache.tomcat.util.compat.Jre9Compat.jarFileNewInstance(Jre9Compat.java:209) at org.apache.tomcat.util.scan.JarFileUrlJar.<init>(JarFileUrlJar.java:65) at org.apache.tomcat.util.scan.JarFactory.newInstance(JarFactory.java:49) at org.apache.tomcat.util.scan.StandardJarScanner.process(StandardJarScanner.java:383) at org.apache.tomcat.util.scan.StandardJarScanner.processURLs(StandardJarScanner.java:318) at org.apache.tomcat.util.scan.StandardJarScanner.doScanClassPath(StandardJarScanner.java:270) at org.apache.tomcat.util.scan.StandardJarScanner.scan(StandardJarScanner.java:233) at org.apache.jasper.servlet.TldScanner.scanJars(TldScanner.java:262) at org.apache.jasper.servlet.TldScanner.scan(TldScanner.java:104) at org.apache.jasper.servlet.JasperInitializer.onStartup(JasperInitializer.java:83) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4929) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:683) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:658) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:662) at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1184) at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1932) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:118) at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:1094) at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:476) at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1617)
