java.io.IOException Stream closed
We are running into the below exception while trying to compile funtions or while launching a portal from other pega(non stream nodes) clusters.
aused by: java.io.IOException: Stream closed
at java.io.BufferedInputStream.getInIfOpen(BufferedInputStream.java:159) ~[?:1.8.0_352]
at java.io.BufferedInputStream.fill(BufferedInputStream.java:246) ~[?:1.8.0_352]
at java.io.BufferedInputStream.read1(BufferedInputStream.java:286) ~[?:1.8.0_352]
at java.io.BufferedInputStream.read(BufferedInputStream.java:345) ~[?:1.8.0_352]
at java.io.FilterInputStream.read(FilterInputStream.java:107) ~[?:1.8.0_352]
at sun.util.locale.provider.RuleBasedBreakIterator.readFile(RuleBasedBreakIterator.java:462) ~[?:1.8.0_352]
at sun.util.locale.provider.RuleBasedBreakIterator.readTables(RuleBasedBreakIterator.java:375) ~[?:1.8.0_352]
at sun.util.locale.provider.RuleBasedBreakIterator.<init>(RuleBasedBreakIterator.java:321) ~[?:1.8.0_352]
at sun.util.locale.provider.BreakIteratorProviderImpl.getBreakInstance(BreakIteratorProviderImpl.java:169) ~[?:1.8.0_352]
at sun.util.locale.provider.BreakIteratorProviderImpl.getLineInstance(BreakIteratorProviderImpl.java:106) ~[?:1.8.0_352]
at java.text.BreakIterator.createBreakInstance(BreakIterator.java:571) ~[?:1.8.0_352]
at java.text.BreakIterator.createBreakInstance(BreakIterator.java:553) ~[?:1.8.0_352]
at java.text.BreakIterator.getBreakInstance(BreakIterator.java:544) ~[?:1.8.0_352]
at java.text.BreakIterator.getLineInstance(BreakIterator.java:483) ~[?:1.8.0_352]
at java.text.BreakIterator.getLineInstance(BreakIterator.java:470) ~[?:1.8.0_352]
at com.pega.pegarules.generation.internal.library.LibraryUtilityBase.wrapJavadocLine(LibraryUtilityBase.java:1164) ~[prprivate-generation.jar:?]
at com.pega.pegarules.generation.internal.library.LibraryFunctionUtilityImpl.generat
