Coforge
"Problem accessing key store java.io.IOException: Invalid keystore format
Hi, We are upgrading from v5.5 to 7.1.9 ( Websphere / DB2-UDB). We completed upgrade, while validating upgrade we see none of the Connect-SOAP services are working. We are getting error in tracer as "keystore Exception: IBMKeyManager: Problem accessing key store java.io.IOException: Invalid keystore format"
in log we see error following errors. Any configuration we have to do after upgrade with respect to Connect-SOAP or it is expcetd to work without any change ? if changes required can someone guide me documentation around it please...
2016-01-07 10:18:39,695 [ WebContainer : 1] [TABTHREAD1] [ctCenterCPM:02.01.01] ( internal.ssl.SSLUtils) ERROR gicone-dev.prudential.com|48.18.70.47|Rule-Connect-SOAP.PruGI-Int-Insured-Insureds-.search2 x186475 - Unable to get environment's protocols java.security.NoSuchAlgorithmException: Error constructing implementation (algorithm: Default, provider: IBMJSSE2, class: com.ibm.jsse2.ec)
2016-01-07 10:18:39,708 [ WebContainer : 1] [TABTHREAD1] [ctCenterCPM:02.01.01] ( internal.ssl.SSLUtils) ERROR gicone-dev.prudential.com|48.18.70.47|Rule-Connect-SOAP.PruGI-Int-Insured-Insureds-.search2 x186475 - IBMKeyManager: Problem accessing key store java.io.IOException: Invalid keystore format
java.security.KeyStoreException: IBMKeyManager: Problem accessing key store java.io.IOException: Invalid keystore format
at com.ibm.jsse2.cc$a_.engineInit(cc$a_.java:7)
