    Royal Bank Of Canada
Last activity: 8 May 2025 7:03 EDT
Data Flow java.lang.illegalstateexemption
Dataflow created to move the records from a table to another data table with transformation. I was able to move around 10k records but 3 records failed with java.lang.illegalstateexemption. This happens during dataset stage where the records will be written into the table. Need ways to enable logs to find more details. Is it possible to get the insert query triggered by the dataflow to store records with dataset in the logs which will help to identify the exact rootcause? Also, where can we find the full stack trace. The stack trace shown in the dataflow is not giving proper details.
com.pega.dsm.dnode.api.dataflow.StageException: Exception in stage: WorkData at com.pega.dsm.dnode.api.dataflow.StageException.create(StageException.java:54) at com.pega.dsm.dnode.api.dataflow.DataFlowStage$StageInputSubscriber.onCompleted(DataFlowStage.java:521) at com.pega.dsm.dnode.api.dataflow.DataFlowExecutor$QueueBasedDataFlowExecutor$5.process(DataFlowExecutor.java:384) at com.pega.dsm.dnode.api.dataflow.DataFlowExecutor$QueueBasedDataFlowExecutor.runEventLoop(DataFlowExecutor.java:218) at com.pega.dsm.dnode.api.dataflow.DataFlow$2.emit(DataFlow.java:331) at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:59) at com.pega.dsm.dnode.impl.dataflow.task.strategy.ExecutionStrategy.executeDataFlow(ExecutionStrategy.java:125) at com.pega.dsm.dnode.impl.dataflow.task.strategy.SinglePartitionExecution.executePartitions(SinglePartitionExecution.java:77) at com.pega.dsm.dnode.impl.dataflow.service.run.ExecutePartitionsRunnable.executeDataFlowWithPartitions(ExecutePartitionsRunnable.java:86) at com.pega.dsm.dnode.impl.dataflow.service.run.ExecutePartitionsRunnable.access$900(ExecutePartitionsRunnable.java:34) at com.pega.dsm.dnode.impl.dataflow.service.run.ExecutePartitionsRunnable$1.run(ExecutePartitionsRunnable.java:67) at com.pega.dsm.dnode.impl.dataflow.service.run.ExecutePartitionsRunnable$1.run(ExecutePartitionsRunnable.java:62) at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:67) at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContextInternal(ServiceHelper.java:305) at com.pega.dsm.dnode.impl.prpc.service.ServiceHelper.executeInPrpcContext(ServiceHelper.java:150) at com.pega.dsm.dnode.impl.dataflow.service.run.ExecutePartitionsRunnable.call(ExecutePartitionsRunnable.java:62) at com.pega.dsm.dnode.impl.dataflow.service.run.ExecutePartitionsRunnable.call(ExecutePartitionsRunnable.java:34) at com.google.common.util.concurrent.TrustedListenableFutureTask$TrustedFutureInterruptibleTask.runInterruptibly(TrustedListenableFutureTask.java:108) at com.google.common.util.concurrent.InterruptibleTask.run(InterruptibleTask.java:41) at com.google.common.util.concurrent.TrustedListenableFutureTask.run(TrustedListenableFutureTask.java:77) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1160) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:59) at com.pega.dsm.dnode.util.PrpcRunnable$1.run(PrpcRunnable.java:56) at com.pega.dsm.dnode.util.PrpcRunnable.execute(PrpcRunnable.java:67) at com.pega.dsm.dnode.impl.prpc.PrpcThreadFactory$PrpcThread.run(PrpcThreadFactory.java:124) Caused by: java.lang.IllegalStateException: Should be handled by the source data observable at com.pega.dsm.dnode.impl.dataflow.resilience.retry.RetryingDataObservableDecorator.emit(RetryingDataObservableDecorator.java:119) at com.pega.dsm.dnode.impl.stream.DataObservableImpl$SafeDataSubscriber.subscribe(DataObservableImpl.java:353) at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:55) at com.pega.dsm.dnode.impl.stream.DataObservableImpl$3.emit(DataObservableImpl.java:176) at com.pega.dsm.dnode.impl.stream.DataObservableImpl$SafeDataSubscriber.subscribe(DataObservableImpl.java:353) at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:55) at com.pega.dsm.dnode.impl.stream.DataObservableImpl$3.emit(DataObservableImpl.java:176) at com.pega.dsm.dnode.impl.stream.DataObservableImpl$SafeDataSubscriber.subscribe(DataObservableImpl.java:353) at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:55) at com.pega.dsm.dnode.impl.stream.DataObservableImpl.await(DataObservableImpl.java:117) at com.pega.dsm.dnode.impl.stream.DataObservableImpl.await(DataObservableImpl.java:106) at com.pega.dsm.dnode.impl.dataflow.SaveStageProcessor.onNext(SaveStageProcessor.java:140) at com.pega.dsm.dnode.api.dataflow.DataFlowStageBatchProcessor.commitBatchInternal(DataFlowStageBatchProcessor.java:147) at com.pega.dsm.dnode.api.dataflow.DataFlowStageBatchProcessor.commitBatch(DataFlowStageBatchProcessor.java:132) at com.pega.dsm.dnode.api.dataflow.DataFlowStageBatchProcessor.onCompleted(DataFlowStageBatchProcessor.java:118) at com.pega.dsm.dnode.api.dataflow.DataFlowStage$StageInputSubscriber.onCompleted(DataFlowStage.java:517) ... 24 more Caused by: com.pega.dsm.dnode.api.ExceptionWithInputRecord: com.ibm.db2.jcc.am.BatchUpdateException: [jcc][t4][102][10040][4.33.31] Batch failure. The batch was submitted, but at least one exception occurred on an individual member of the batch. Use getNextException() to retrieve the exceptions for specific batched elements. ERRORCODE=-4229, SQLSTATE=null at com.pega.dsm.dnode.impl.dataset.database.DatabaseSaveOperation$AbstractSaveOperation.execute(DatabaseSaveOperation.java:182) at com.pega.dsm.dnode.impl.dataset.database.DatabaseSaveOperation$1.executeExposedLogic(DatabaseSaveOperation.java:526) at com.pega.dsm.dnode.impl.dataset.database.DatabaseOperationsUtil.lambda$observableForDatabaseOperation$0(DatabaseOperationsUtil.java:73) at com.pega.dsm.dnode.impl.dataset.database.DatabaseOperationsUtil$$Lambda$358/0x000000002cf48930.emit(Unknown Source) at com.pega.dsm.dnode.impl.stream.DataObservableImpl$SafeDataSubscriber.subscribe(DataObservableImpl.java:353) at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:55) at com.pega.dsm.dnode.impl.dataset.database.RetryableSave.lambda$save$0(RetryableSave.java:43) at com.pega.dsm.dnode.impl.dataset.database.RetryableSave$$Lambda$4609/0x00000000599bf510.emit(Unknown Source) at com.pega.dsm.dnode.impl.stream.DataObservableImpl$SafeDataSubscriber.subscribe(DataObservableImpl.java:353) at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:55) at com.pega.dsm.dnode.impl.stream.DataObservableImpl$3.emit(DataObservableImpl.java:176) at com.pega.dsm.dnode.impl.stream.DataObservableImpl$SafeDataSubscriber.subscribe(DataObservableImpl.java:353) at com.pega.dsm.dnode.impl.stream.DataObservableImpl.subscribe(DataObservableImpl.java:55) at com.pega.dsm.dnode.impl.dataflow.resilience.retry.RetryingDataObservableDecorator.produceRecords(RetryingDataObservableDecorator.java:147) at com.pega.dsm.dnode.impl.dataflow.resilience.retry.RetryingDataObservableDecorator.emit(RetryingDataObservableDecorator.java:102) ... 39 more Caused by: com.ibm.db2.jcc.am.BatchUpdateException: [jcc][t4][102][10040][4.33.31] Batch failure. The batch was submitted, but at least one exception occurred on an individual member of the batch. Use getNextException() to retrieve the exceptions for specific batched elements. ERRORCODE=-4229, SQLSTATE=null at com.ibm.db2.jcc.am.b4.a(b4.java:502) at com.ibm.db2.jcc.am.Agent.endBatchedReadChain(Agent.java:434) at com.ibm.db2.jcc.am.ko.a(ko.java:5664) at com.ibm.db2.jcc.am.ko.c(ko.java:5216) at com.ibm.db2.jcc.am.ko.executeBatch(ko.java:3206) at com.ibm.ws.rsadapter.jdbc.WSJdbcPreparedStatement.pmiExecuteBatch(WSJdbcPreparedStatement.java:1146) at com.ibm.ws.rsadapter.jdbc.WSJdbcStatement.executeBatch(WSJdbcStatement.java:856) at com.pega.pegarules.data.internal.store.DatabasePreparedStatementImpl.executeBatch(DatabasePreparedStatementImpl.java:491) at com.pega.dsm.dnode.impl.dataset.database.DatabaseSaveOperation$UpdateOperation.process(DatabaseSaveOperation.java:320) at com.pega.dsm.dnode.impl.dataset.database.DatabaseSaveOperation$AbstractSaveOperation.execute(DatabaseSaveOperation.java:176) ... 53 more
