Removing data objects/instances after a predetermined period
Is there an out-of-the-box feature for archiving or deleting data objects/instances, similar to the existing feature for work objects?
Thank you.
Thank you.
Hi @MarielR5,
Based on my understanding, There is no out-of-the-box feature specifically designed for archiving or deleting data objects or data instances in the same way that work objects (cases) can be archived or deleted using the Pega Case Management features.
Mohd Qizer Uddin
